Wheelspeed sensor.
Old Mar 24, 2010 | 01:55 PM
Calmingstorm's Avatar
Member
Default Wheelspeed sensor.
So, I'm sure a lot of you read about my idiocy and breaking my upright/wheelspeed sensor. The sensor would read 1 KPH all the time in vagcom, so - I went to the junkyard, got another sensor...issue is, this sensor had a cut in the wire, so I spliced it and taped it.
Still reading 1 KPH no matter what. My question is : Can these wires be spliced? Or is it a huge no no, and two : Is it at all possible that I screwed up the axle some how? Since isn't that how it reads wheelspeed? some magnetic marking on the area near the spline?
*edit* The new sensor, of course could be bad too. That would just be bizaar luck, though.
Old Mar 24, 2010 | 11:30 PM
Dallas09's Avatar
Splicing should be fine, the sensor is based on pulse and voltage variation I think and not resistance. It isnt likely the axle got messed up, you would probably have a reading that varied, but that was still different from the other wheels if that were the case. You might try pushing it in a little further, that was my problem (depending on what year, they had screws to hold them later I think).
Old Mar 25, 2010 | 06:36 AM
Member
Turns out my tone ring broke during removal and stayed stuck to the upright, and broke out during hammering of the bearing. Oops
Old Mar 25, 2010 | 09:11 AM
hiwords's Avatar
how did you break your tone ring during a sensor swap? you do know that the tone ring is inside the hub right?
Old Mar 25, 2010 | 11:05 AM
Member
Wasn't just a sensor swap, I swapped the entire spindle/upright. Mine was warped and was chewing through bearings like noones business.
Old Mar 25, 2010 | 12:48 PM
auditech79's Avatar
Yeah i was gonna say its easy to damage the ring. I have broken a few in my day changing CV boots.
Old Mar 25, 2010 | 02:41 PM
Member
Hey guys, went to the junkyard and grabbed a new tone ring. All is well, abs in full function even with my double splicing. I do need to get a proper wheelspeed sensor, as im sure the splice will eventually wear. Or re-splice it the proper way, depends on if i'm lazy or not
neomaxddr
Apr 1, 2009 03:16 AM
