2007 Audi A4 Driver Seat Woes
Hi all,
So my car filled up with water, and I pulled the driver's seat so I could pull up the carpet and dry things out. I temporarily put it back in to go somewhere, and noticed the rails were out of alignment. Upon further examination, it seems that one side is off relative to the other, so I extended the seat all the way forward to line everything up. Perfect! Except now it's stuck! One side will go back, but the center console side won't move. Looking under the seat, I see that the horizontal motor has fallen loose. It still spins, but it's not engaging the worm gear. Any ideas here? Obviously, I can't remove the seat any more because it's covering one bolt. The motor that has fallen loose has left a black plastic bracket in place, but I'm not sure even getting it to fit back in will work.
By the way, since I'm here, how do you get the CCM out of the protective box!
Thanks in advance!
Baldwyn
Thanks in advance!
Baldwyn
Traveler side seat won't push ahead. Any remaining capacities work. Conversed with seller, there reaction was, it very well may be 4 differnt things (swithces/engines). Searching for any exhortation to keep away from vendor overhauling my vehicle and maximizing my Mastercard. Vag Com didn't show any codes for this. Sucks cuz the seat is right forward.
Nox Vidmate VLC
Nox Vidmate VLC
The plastic part of the seat-back on the driver's side came loose from the part that actually attaches to the seat (it separated where it's glued together). I tried reconnecting it with some 3M double sided panel adhesive, but it didn't hold.
Speed Test
Speed Test
Audi Hatchback Details
Used Audi A4 for Sale
Audi Q5 For Sale
Audi S4 For Sale
Audi Q5 For Sale
Audi S4 For Sale
deep6
Jun 3, 2006 02:25 AM
