A4 Gives problems in Wet weather.
Old Mar 8, 2012 | 02:58 PM
jafferman's Avatar
Default A4 Gives problems in Wet weather.
Hello
When I drive my car in wet weather(snow / more so rain)
I get the ESP, EPC lights, This happens when I get on the highway and switching gears (6 speed manual) Then i feel a drop off and then EPC light comes on.
When I do get to the city and i stop at a light. Sometimes there is no acceleration from the pedal at all, Car just sits and idles. Until I restart the car then the lights turn off momentarly and the car runs like normal.
I had a cracked ecu box cover, replaced brake light switch and the accelerator pedal. I also clearned the MAF using electrical cleaner. But i have pinned it down to it only happens when the weather is "WET"
Vag com pulled codes brake light switch which has been replaced 3 times recently. Usually the brake light causes the ESP and the other lights then later on the highway the EPC code follows.
Any advice?
Old May 6, 2012 | 07:56 PM
Windward's Avatar
My A4 B6 does this whenever I pressure wash the car and rinse the wheel wells.
Any advice out there?
Old May 6, 2012 | 11:46 PM
ImTheDevil's Avatar
You may be soaking the ABS sensor wiring connections.
Old May 7, 2012 | 06:12 AM
derZeck's Avatar
Dumb question, but are all your inner fenders installed?
Old May 7, 2012 | 09:56 AM
jafferman's Avatar
Wow thanks for leading me in that direction, I do recall this problem happened after I installed a new wheel speed sensor. I did have a crack in the ECU cover from the previous owner, but i never thought to check the abs wires in the fender. I might have not seated in properly. I do notice this happens only in really wet weather, light rain or medium rain the car abs system works fine but as soon as it gets into heavy rain i run the risk of stalling.
I will check this out after work today to see if i placed back the drivers side fender properly.
Old May 7, 2012 | 09:40 PM
Windward's Avatar
I do have the inner fenders. The car is stock. Would anybody have a Picture of what I should look for?
Thanks for the help.
Old May 8, 2012 | 11:46 AM
jafferman's Avatar
Connected to the wheel wheels is a wheel speed sensor connection that leads to the top back of the fenders, It is closed off with a rubber stopper type plugin but that may be loose or letting water in
spinradical
Nov 18, 2014 01:46 PM
ninjatturtle
Dec 2, 2008 11:28 PM
connman
B7 Models
Feb 20, 2008 11:35 AM
Chingy
Dec 8, 2006 05:09 PM
