aargh, another problem with my a4
Old Feb 27, 2010 | 01:24 PM
hitman1978's Avatar
Default aargh, another problem with my a4
my a4 avant now has another problem, seems i have a possessed rear wiper. sometimes it works just fine, then other times it has a mind of its own, stops when it wants, starts when it wants even with the wiper turned off. and it very rarely stops in the right position, anyone got any ideas what could be the cause?
Old Feb 27, 2010 | 02:42 PM
Dan1969's Avatar
The stalk maybe?
Old Feb 27, 2010 | 03:03 PM
hitman1978's Avatar
i thought the same, but front wiper working fine, also, just been out in it and found out my windows no longer wind up or down using the key, its starting to make me consider seeling the car ive had that many little faults
Old Feb 27, 2010 | 09:07 PM
Dan1969's Avatar
They're normal faults for Audi. It could still be the stalk though. I don't know how the system on the avant is but isn't the rear wiper integrated into the same stalk as the wipers on the front?
Old Feb 28, 2010 | 05:43 AM
hitman1978's Avatar
yes, its on the same stalk, just seemed odd that only the rear is affected, i will give it a try
Old Feb 28, 2010 | 01:14 PM
Dan1969's Avatar
Most likely the stalk then.
http://www.audizine.com/forum/showth...ring+Wheel+DIY
That's a DIY for teh steering wheel swap, you can get to the stalks that way.
Old Mar 9, 2010 | 02:30 PM
hitman1978's Avatar
ive also noticed that now when the rear wiper starts playing up, so does my fuel gauge and drivers side electric window control, my fuel gauge claims that i used 120 miles of fuel to do 10 miles, i know its thirsty at times but definately a fault
Old Mar 9, 2010 | 06:58 PM
Dan1969's Avatar
hmm, then you must have a short... is dufficult to find it, look for the best of your ability to find a short or messed up wire somewhere... Also check all connections, I'd still check the stalk to make sure is connected properly, also the stalk might be causing a short, difficult to say though...
Old Mar 10, 2010 | 02:34 PM
hitman1978's Avatar
thanks, looks like im spending my weekend with my car in bits, determined to sort it myself though, you can guarantee that if i took it to a garage it would be the last thing they find, or so they would say
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
derrat
Sep 12, 2008 12:43 AM
skibum0019
Jul 6, 2004 11:24 AM
