Ac issue
Old Jun 20, 2012 | 01:23 PM
rdltmc3's Avatar
Default Ac issue
Ac doesn't blow cold when at idle but anything above 1,500 RPMS it blows cold. Pressure is fine, clutch engages, both fans are working, and the condenser is clean.
Any thing I can do to fix this or is it just an Audi thing?
Old Jun 20, 2012 | 04:46 PM
sburkeatqmi's Avatar
I have the same problem. Going down the road I'm fine. Stopped at a light, no bueno.
Old Jun 20, 2012 | 05:29 PM
rdltmc3's Avatar
I'm not even saying down th road, I just press the gas in park and cold air from the higher rpm.
Check your secondary fan
Old Jun 21, 2012 | 12:42 PM
pa4ul's Avatar
so u checked for leaks and everything. I would think it might since the car is sitting at idle the compressor is having to work overtime to cool air and no cool air is hitting the condensor coil. . I thought most ac's do this a bit while at idle.
Old Jun 21, 2012 | 05:49 PM
Audi Tek's Avatar
Tech Certified
you most likely have a low charge.... an a/c service is recommended over those top of bottles.
Old Jun 21, 2012 | 06:22 PM
pa4ul's Avatar
Yea those over the counter bottles arent very good. If u do recharge let a professional do it.
nelson0639
Dec 8, 2014 04:44 PM
hotswaps
Aug 8, 2013 05:50 PM
hotswaps
May 27, 2013 07:02 PM
Dallas09
Feb 14, 2009 05:08 PM
2001A6
Jan 9, 2009 02:41 AM
