Auxiliary Cooling fan removal 2004 A4 1.8T
Old Jul 31, 2013 | 06:40 PM
jordan's Avatar
Default Auxiliary Cooling fan removal 2004 A4 1.8T
I noticed the cooling fan (auxiliary) does not come on with the AC. The primary fan works normally. Some easy troubleshooting found that voltage went to the fan when the AC was turned on, and dropped to zero when turned off. The module is not the issue.
I guess I could use the instruction on cleaning the brushes and commutator before purchasing a new one. I cant however, figure out how to remove the fan from the car.
Can I avoid radiator removal, or avoid removal of the whole dual fan assembly?
Thanks,
Jordan
Old Aug 1, 2013 | 08:26 AM
tofast2belast's Avatar
you need to remove the core support and pop the fan out. its clipped in the core support.
if you look up DIY timing belt it covers how to do this.
a2thy
Aug 31, 2009 03:56 PM
mcclendonthaboss
Jul 22, 2009 12:15 AM
Audi A Fizzle
May 23, 2009 04:47 PM
samir
Oct 29, 2008 12:58 AM
insuite
May 3, 2005 11:03 PM
