CEL, Running fine? Here are the codes...
Old Mar 31, 2012 | 09:41 PM
mochsl99's Avatar
Default CEL, Running fine? Here are the codes...
2003 A4 1.8t Avant Quattro, 84,000 miles.
My CEL just came on. I recently completed 80K service (oil, timing belt/water pump, air filter(s), plugs).
Ran VAGCOM and here are the codes:
2 Faults Found:
17519 - Oxygen (Lambda) Sensor Regulation: Bank 1
P1111 - 002 - System too Lean - MIL ON
17544 - Fuel Trim: Bank 1 (Add)
P1136 - 001 - System too Lean
Readiness: 0000 0000
I'm just starting to troubleshoot this, but will I damage it by continuing to drive the car until I figure it out? Any input appreciated.
Thanks in advance.
Old Mar 31, 2012 | 10:51 PM
mochsl99's Avatar
Default Check valve problem?
Could this check valve cause the codes/CEL? It's pretty much eaten up by corrosion:
Old Mar 31, 2012 | 11:59 PM
mochsl99's Avatar
Default Found the leak... now, part #?
The leak is a fractured check valve at the rear of the valve cover, in pretty tight quarters:
Now I just need to figure out: Will any check valve do? Or do I need a specific part #? EuropaParts.com: In-Line Check Valve - 058905291K - OE Aftermarket
Old Apr 1, 2012 | 09:47 AM
M5S5's Avatar
Tech Certified
Get the factory part only!
Old Apr 3, 2012 | 07:46 PM
Karl's Avatar
How did this turn out? Were you able to get it fixed?
nickmercedesbenz
Feb 7, 2014 06:11 PM
spaceboy3000
Oct 4, 2013 05:54 PM
kerosene
Jun 16, 2010 05:41 PM
BuckWyld
Sep 8, 2007 02:57 AM
