Cluster Panel All Gear Positions Light up.
Old Jul 15, 2012 | 02:49 AM
CoAudiA4quattro1.8t's Avatar
Default Cluster Panel All Gear Positions Light up.
Hello I'm new to this hope this is the correct place to post this. I bought a 2002 A4 Quattro 1.8t, automatic transmission I did not notice all the gears being lit up when I bought it. So when I move the the shifter from Park to Drive I see it on the cluster panel. But as it engages all gear positions are lit up and stay that way. In the last 8 weeks the car drove fine except for two separate times. when acting up, seems very sluggish, had gas pedal to floor. Giving bauged down sound when pressing the gas pedal. What seemed to remedy this is to turn it off and let it sit for an hour or two. Ive been reading up on this. Is this the TCM unit failing? no other symptoms at all. Any help would be greatly appreciated
Old Jul 16, 2012 | 04:35 AM
Trog675's Avatar
i have the same issue with my 04. Seems to only do it when i shift into reverse. Going to the shop tomorrow, ill let you know what they find
Old Jul 16, 2012 | 05:31 PM
Audi Tek's Avatar
Tech Certified
most likely you have a water leak into your car..... water got inside your TCM and shorted it out.
Old Jul 16, 2012 | 07:43 PM
Default "Cluster Panel All Gear Positions Light up
Thanks for replying ,Yeah let me know what you find out with your 04. And replying to the the comment my " TCM Box" may have a crack in it. I thought the same thing. Like everyone else, Im not going to the dealer. Is the next step to to do the software test? To be sure. I forget the name of that Starts with a V???? Then locate tcm and tcm box?
Car information:
2002 Audi A4 Quattro 1.8t Automatic
Vin: waul68ex2a185871
Thanks for you help
Old Jul 16, 2012 | 07:51 PM
02A6Beau's Avatar
when all the gear indicators light up like that it is an indication of the dreaded "limp" mode. Transmission defaults to 3rd gear and your car will run like sh...poorly. The vag-com can scan the transmission module and tell you what the faults are. The most common causes are a bad sensor in the trans or damage to the transmission module (TCM), usually from water. The module is located in the passenger footwell under the carpet, in front of the passenger seat.
Old Jul 17, 2012 | 01:40 AM
Trog675's Avatar
funny thing with mine is if i put into D first it wont go into "limp" mode, but if i shift to R first it does. Then if i turn car off for about 1 minute, then shift to R its OK. Car is currently in shop to see exactly is going on. Ill keep you posted, should hear something tomorrow.
Old Jul 20, 2012 | 05:20 PM
Trog675's Avatar
of course it wouldnt go into limp mode while the car was at the shop all week, but as soon as i get the dam thing home, guess what?
Old Aug 30, 2018 | 01:11 AM
jgoeke's Avatar
Did you ever figure out what the problem was? I have the exact same issue with my 2003 A4
Nizzy
Nov 11, 2015 03:58 PM
A4rings_731
Nov 6, 2010 12:22 AM
jpcallmotor
Jul 9, 2010 01:41 PM
freakaftr8
Jan 8, 2009 12:57 PM
cjacque
Aug 5, 2008 09:14 PM
