ESP light staying on A4 B6
Old Feb 24, 2012 | 03:08 PM
  #21
budhani786's Avatar
Originally Posted by pa4ul
hmm ill have to go double check. But last time i tried to clear the codes it wouldnt let me. The only way i know u can is if u purchase the vcds software from rosstech for $99.00.
Mines the free one. i have noticed that sometimes when the car is started it will not clear it. is your car idling when you try to clear it or just on but not started?
Old Feb 24, 2012 | 05:56 PM
  #22
pa4ul's Avatar
no i never have the car on when i scan. just turn the ignition on for power but i never crank it over.
Old Feb 29, 2012 | 03:55 AM
  #23
Renifer's Avatar
i have windows vista. so it worked like a charm. Basically the ports have to match up from your device manager and through the vagcom program. If u get unrecongnized port just switch your plug to a different usb outlet. Then go in a switch the com port in device manager and vagcom. If u run into any problems pm me and ill walk u through as best i can.
I sent you a PM.
Thanks Pa4ul.
Old Feb 23, 2013 | 02:19 PM
  #24
MacValentine's Avatar
I don't know why the guy on the first page was saying the brake light switch was gonna run you $230
These guys are decent:
Audi A4 Brake Light Switch at AM Autoparts
I'm having a similar issue as you, but my cruise works fine. ESP light doesn't bug me as the CEL.
I was told by the techs at the stealership that I need to change mine too. Kinda makes sense when I press the check button it shows the BRAKE with the circle around it.
Old May 11, 2013 | 07:50 PM
  #25
Expplucky's Avatar
if someone bought the program i can torrent it......
Old Jul 8, 2013 | 07:30 AM
  #26
Tesladroom's Avatar
Hey!
I have also problems with ESP.
When i used VAG-COM i got such error codes
01826 - Sensor G85
18057 - Powertrain
Any help how to fix ?
Old Jul 8, 2013 | 01:11 PM
  #27
pa4ul's Avatar
Originally Posted by Tesladroom
Hey!
01826 - Sensor G85
18057 - Powertrain
01826 - Ross-Tech Wiki
18057/P1649/005705 - Ross-Tech Wiki
Old Jan 30, 2020 | 09:12 AM
  #28
Peter Bladek's Avatar
Default Esp
Originally Posted by Audi Tek
haha.......... OMG.
An Audi tech really told you your ESP light is on for hydraulic mounts...?
Thats the worst thing i ever heard. The hydraulic mount fault is there because someone left the sensor unplugged last time they did and oil change.
Most common problems for esp.... Wheel speed sensors, brake light switch, damaged tone rings, or steering angle sensor
Check MAF SENSOR Somtetimes that happens when engine idle or air filter
A4doggy
Jan 14, 2012 04:24 AM
Brautty
Jan 8, 2012 05:41 PM
sdsponger
Jun 22, 2009 08:09 PM
oziaudi
Jun 18, 2006 10:07 PM
blast
Mar 19, 2005 06:55 AM
