Flood Car! No Windows No Sunroof No Interior Lights! HELP!
Just purchased a flooded 05 audi a4, dont think it was flooded that bad because the interior is pretty clean and most of the stuff works. The problems that im having is none of the windows will go down, the sunroof doesnt open, the interior lights dont come on, and the trunk button doesnt work. Ive searched and cant find anything. Any help is appreciated.
could bee your body module which is located underneath the dash. Ur gunna look underneath the drivers side. The panel that holds the manual is what ur looking at. There should be two screws on the corners of that panel. Unscrew them. Then pull the fusebox cover. There will be one more screw there. Then the panel pops out and ur body module is loacted underneath there. Is has like 3 relays on it. IF ur car was flooded and flooded pretty bad then this probably has some moisture in it causing a fried circuit board. Do all your other lights and stuff work Cuz i know that module controls all the uinterior/exterior lights and so on.
gjcgjc13
09-08-2015 01:49 PM
Dan.petro
02-10-2014 03:34 PM
ryanbz2001
06-28-2012 06:57 AM
markymarc
03-11-2012 01:02 PM
