Giving $ for your answer!! HELP!!
Old Feb 12, 2013 | 09:03 PM
Motormorgan's Avatar
well ill install my gauge on friday and then give a follow up. chime in if anybody else has ideas to look for while im into it this weekend
Old Feb 13, 2013 | 06:19 PM
pa4ul's Avatar
try some seafoam. Then emtpy oil and reset the idiot light. Then refill and check back. sounds like sludge.
Old Feb 13, 2013 | 07:07 PM
but my engine isn't sludged.. at least I don't think. I dropped pan and pulled valve covers and its clean as a whistle. Had a 4 stage chemical clean from the dealer along with pickup tube cleaned up. but your saying it could still be sludge? that seems very surprising to me.
Old Feb 14, 2013 | 01:23 PM
pa4ul's Avatar
WEll the fact that you get an intermintant light tells me something is causing the pressure to drop. and just to be clear did u actually watch the dealership drop the pan and clean out everything. Alot of times the tech's will do a half **** jobto make sure you come back for more spending. Just saying. . . .Oh im wondering what weight oil did you use? Also try turn on the car and pull the dipstick out. If it sounds fairly loud i would lean towards your breather system not holding vaccume to the crankcase.
Old Feb 14, 2013 | 07:11 PM
The dealer is a long time close family friend so I trust his work. Have gone to him many years for the family VW's. Im not positive on the weight, I have the cans at home that I can check tonight. Also tonight I will try the dip stick test. What weight is recommended? Ive heard a few people suggest a heavier weight than the dealer recommends?
also to clarify that the pressure guage has been hooked up and getting good reading while the oil pressure light comes on. Hoping to verify this with aftermarket guage constantly hooked up.
Old Feb 18, 2013 | 12:41 PM
pa4ul's Avatar
so what was the word on weight used?
Old Feb 19, 2013 | 10:38 AM
When the dealer changed my oil I ordered 2 extra quarts and without asking
They gave me 5w40 so I can assume that's what they put in.
Old Feb 19, 2013 | 10:41 AM
  #18
Also an update on the gauge, the test port above the filter rounded off (even with extreme care in trying to remove it!) so I've ordered another fitting and it won't be on til this weekend. Light only has come on a few times. Only when hot and at about 1500-1600 rpm then goes right away. Any more ideas while I'm waiting for this fitting?
Old Feb 19, 2013 | 12:22 PM
  #19
pa4ul's Avatar
so when the your at low rpm the red light will come on right? But once u get above that range the light goes away. i just want to be clear.
Old Feb 19, 2013 | 12:30 PM
  #20
Yes, anything above or below 1500/1600 rpm the light will go right away. It's only at that rpm and only when the oil is hot. As for my cornering theory that's been disproven last weekend
