The guts of a Secondary Air Pump
Old Jul 28, 2009 | 08:52 AM
splat10's Avatar
Thumbs down The guts of a Secondary Air Pump
So i took out my SAP that hasn't worked for a while now and tested it. Completely dead when hooked to 12v. No humming, not even a sign of life. So i thought, hmm maybe i can clean the motor and fix it up to work. LOL yeah right. I got the base cap off ok and probably could have epoxied it back on ok but the fan side wasn't budging. After seeing waht the motor leads looked like i knew it was toast anyway so i started hacking away at it and what i found was beyond my expectations.
The condensation dripping into the motor with no place to excape did a job on it. There really needs to be a weep hole in the duct or housing somewhere. I steel motor housing in a sealed unit at the bottom of a drip loop is a superb design Audi. Good job on that one. no wonder these things fail so often.
Attached Thumbnails The guts of a Secondary Air Pump-p7270037.jpg   The guts of a Secondary Air Pump-p7270040.jpg   The guts of a Secondary Air Pump-p7270043.jpg   The guts of a Secondary Air Pump-p7270041.jpg   The guts of a Secondary Air Pump-p7270038.jpg
Old Nov 3, 2010 | 12:35 PM
Slinger64's Avatar
Default condensation in secondary air pump
My mechanic, Foreign Car Guru, says to drill a 1/8" hole in the bottom of the secondary air pump to let water drain.
audiup
Apr 9, 2013 09:14 AM
jeeps5
Sep 22, 2011 06:01 PM
dph138
Mar 29, 2006 07:25 PM
dab_master
Mar 10, 2006 11:50 PM
