Have I blown my engine?! PLEASE help!
Old Jan 17, 2013 | 07:02 AM
QUIGGS2001's Avatar
Default Have I blown my engine?! PLEASE help!
Hi guys,
New to the forum, from N.Ireland.
Last night my mechanic picked up my '04 1.9TDI B6 A4. Ive been having problems with the heating system. IE: only getting warm air when car is moving/engine is in motion, then cold air when car is idle. Temperate guage never moves past 90 by the way. So anyways, lastnight he's diagnosed the water pump was broken and not circulating water/coolant at all.
On his way back to my house to drop off the car, he calls me to state he was driving along, heard a loud ping, and lost all power of engine. Pulls over, seems to be excess oil on the road and on the side of engine block. Engine wont start. Hes figured its possibly blew a piston down through the bottom end, through the sump, or out the side of this block. Thus possibly meaning a new engine?!
Could anyone shed any light on this. Im no expert, but Im pretty sure a car shouldnt be driven with a broken water pump? What damage could this have caused?
Old Jan 19, 2013 | 09:37 AM
ImTheDevil's Avatar
Sounded to me like you had a clogged heater core - your description of the conditions for heat are typical of that. As for what happened, it could well be blown. If the water pump was broken, long as the TDI is like the gas engines, your timing belt would be off as well. If the pump's shaft bearing was shot you'd be leaking coolant. Need to get in there and see what's up. Here's the thing - if you dropped a piston, then the driver was beating the **** out of it. That doesn't just happen by itself.
Old Jan 20, 2013 | 07:36 AM
QUIGGS2001's Avatar
Thanks for the reply. He flushed the heater matrix and found no gunk at all. So im giessing shes overheated with no water pump, or hes been horsing the engine so hard shes blown
bkurowski011
Nov 19, 2011 05:12 PM
broken98c5
Jul 29, 2010 08:10 AM
dab_master
Oct 5, 2007 08:37 AM
ugcpower.com
Jun 15, 2006 10:34 PM
ugcpower.com
Jun 15, 2006 08:02 PM
