Help with headlight issue
Old Jul 18, 2013 | 02:06 PM
budgetbuild's Avatar
Default Help with headlight issue
Hey Guys,
Ive tried searching everywhere and cant find anyone who has the same issue as I do so hoping you can shed some light on this.
about a week ago the right front turn signal would stop working occassionally, i would get a warning on my display and then it would go away. Went to the store and ordered a new one. Stupid me let the associate look up the part number and i was out the door. I pulled my right front headlight assembly and low and behold wrong bulb. I put everything back and it was back to normal for a couple of drives. now, none of the front right lights work in the entire assembly. I get these errors on my Driver HUD:
Front right Turn signal
Right Parking light
Right Dipped Headlight
Right main beam headlight.
any ideas as to the cause? I've re-seated the assembly, checked the fuse box to find out there are no fuses for either headlight. Research has told me it could be a hazard relay?? I've done a lot of repairs (turbo, radiator, heater cores etc) myself however electrical systems are not my strong suite.
Any help will be greatly appreciated!!
Old Jul 18, 2013 | 05:06 PM
ECS Tuning's Avatar
Sponsor
Check all the connections, inside the headlight and where the headlight connects to the rest of the wiring harness.
I highly doubt its the hazard switch.
I would still get the right turn signal bulb it's probably on its last legs.
OEM part number for the bulb is N10475902
Jason
Old Jul 18, 2013 | 06:22 PM
pa4ul's Avatar
jason is right. I would check the connections at the rear of the housing! Might just have a loose connector.
Old Jul 19, 2013 | 11:29 PM
Solved! I used a meter to check the wiring, it was shorting out where the wires wrapped around a piece of sheet metal, fixed it with some electrical tape and we are good to go! Thanks for the responses though guys!!
bplac479
Apr 30, 2010 11:04 AM
warranty225cpe
Feb 15, 2010 09:43 PM
mdemisem
Feb 11, 2009 08:06 AM
Influentialstylez
Mar 29, 2007 04:30 AM
tuscanitnr
Dec 23, 2006 10:41 PM
