I am having problems at high rpm boost issues
Old Jun 2, 2012 | 07:57 AM
tofast2belast's Avatar
Default I am having problems at high rpm boost issues
My car is an 05 A4 Quattro 6mt with apr stage 1 and forge motor sport hybrid diverter valve. I have the valve turned 22 clicks
The low end torque feels good all the way up until about 5k to 6k is when i start feeling the boost is varying. It feels like the waste-gate is fluttering.( i can hear the turbo re spooling in this section as if boost pressure dips then comes back and dips again. the turbo sound is like "swhsss"
Only reason I said waste-gate flutter is because I owned a turbo civic before and when maxing out the waste-gate it would flutter and feel the same way.
If you know what incorrect ignition timing feels like, it feels the same way almost just not as prominent.
The second issue I am experiencing is if I am cruising lets say in 6th gear, normal driving. If I down shift to 5th or 4th while cruising, then hit the throttle to accelerate, I get the feeling of a misfire or back fire. I can on replicate this issue if I am cruising at constant speed for 1-3 minutes it will do it again if I down shift.
I have changed the plugs and oil change, cleaned my injectors(took them out and hooked up to external pump to pump acetone and sea-foam through injector and reverse pumped the injector also).
Old Jun 4, 2012 | 07:08 PM
Audi Tek's Avatar
Tech Certified
Probably blew up the turbo....... Stock turbo's can't take all that much abuse
Old Jun 5, 2012 | 01:22 PM
pa4ul's Avatar
do you have a cell? HAve u replaced your coils?> HAve you checked for vac leaks?
Old Jun 6, 2012 | 10:22 AM
Only cel I get is for idle control higher exceeded upper limit. But the issues I am having occurred before this. I know what causes the idle thing because my throttle body fails adaptation since last week
TeeterTawter
Jan 20, 2013 12:14 PM
timothy1
B7 Models
Dec 6, 2012 10:28 PM
Rxmfn7
Dec 12, 2009 01:09 AM
Justin_72
Aug 11, 2007 08:56 PM
greenday
May 21, 2005 12:59 AM
