Need info on tuning an A4 1.8t
Old Feb 26, 2009 | 01:21 PM
bds6867's Avatar
Default Need info on tuning an A4 1.8t
I am looking for a d/d and the a4 1.8t is at the top of my list, but i am going to tune it. and i would want to get at least 300hp out of it. How easily can this be done, and with what mods? and am i going to mess up the internals of the engine? and if so what would i need to up grade to keep it strong and reliable?
any help would be much appreciated.
Old Feb 27, 2009 | 12:10 PM
nyone8t's Avatar
chp or whp? The internals should hold up depending on how many miles the car has/how well it was maintained by the previous owner. To achieve either goal your looking at a bigger turbo, inj, inlet pipe, exhaust, fmic, clutch and some sort of tuning depending on the route you choose.
Heres the best thing to look at https://www.audiforums.com/forum/sho...haust+manifold
Im actually about to do a gtrs swap on mine, I'll do a write up on the install in the nxt few weeks.
Old Feb 27, 2009 | 01:18 PM
euro_2nr's Avatar
Keep it under 300whp/tq and you'll be fine. But as a preventative measure to a compression/leakdown tests to determine how good your motor is. The power is attainable depending on your budget. For a reliable, well built 300whp DD exect $5-7.5k in parts plus labor. Of course you can go cheaper routes but it may break down and cost you double in the long run.
Old Feb 27, 2009 | 03:48 PM
bds6867's Avatar
How much whp can you get from that turbo with setup? and how much are you hoping to get?
Old Feb 27, 2009 | 03:50 PM
wolfdog's Avatar
I'll keep it short: get a GTRS Eliminator kit once you get the car. You'll be happy.
Check out the Eurocode site for information: Eurocode 1.8T Audi turbo kits
Old Feb 27, 2009 | 05:15 PM
nyone8t's Avatar
Im hoping to get into the high 200's people have made into the 300's on the turbo but I have a high mile motor and I want it to run until I build it.
If you go to supremepowerparts.com they have the gtrs kit for $1399, you need 440cc inj. usrallyteam.com has them for $200, I went with an atp manifold $400, neuspeed.com has an inlet pipe for the gtrs for $300 (if anyone knows of a better route for an inlet pipe let me know) then you need software, revo has a tune for that setup for I believe $700. Those are your bare essentials you also need to have all your other bolt ons done and a new clutch
Old Feb 28, 2009 | 05:09 AM
bds6867's Avatar
I heard the k04 tb gives you something like 240 and 280 f-p, but doesnt the stock tb with injectors and software give you close to that, like 230 and 270? if thats so why swap the turbo
Old Feb 28, 2009 | 10:51 AM
Pablo_Ottawa's Avatar
Personally, I'd go
Chip with injectors
K04 BT
Cat back
That should create enough power to make you **** your pants off the start
Old Mar 1, 2009 | 02:47 AM
nyone8t's Avatar
A k04 on a b6 will give you maybe a +15whp and youll be around 250ftlbs of torquebut the power will be all in the low end. Its a spike then its just past its effiency level. Look at the graph chaos92287 provided in that first link I posted . Look at the curves for the different setups and you can get a good understanding of it.
vair_17
Sep 9, 2008 01:01 PM
Audinam
Dec 19, 2007 11:43 PM
jjuzwik
Nov 16, 2007 06:37 PM
dogface79
Jul 2, 2006 06:17 PM
Lhillenb18
Jun 27, 2005 01:24 AM
