No fuel. Engine Cuts Out. 2005 2.0 Tdi A4
Old Jan 15, 2014 | 06:21 AM
tweety's Avatar
Default No fuel. Engine Cuts Out. 2005 2.0 Tdi A4
The other day whilst getting the MOT on the car it just cut out. It wouldn't run at any revs for more than a few seconds.
We changed the fuel filter but whilst doing so we lost a load of fuel as the pump was still pumping fuel as soon as we removed the plastic connector off the top of the fuel filter. The car did not have the keys in the ignition. It was really squirting it out every time we lifted the connector off the front of the filter. So we disconnected the battery and changed the filter. We primed the new filter with new diesel and it started and ran as normal for ages. The MOT test complete I drove it home maybe 2 miles.
The car stood for 2 days and then I took it out for a drive. Broke down about a mile from home. Same symptoms, just cut out but this time when driving. Would not start again.
I took off the same connector off the top of the filter and this time no pumped fuel. We tried starting with this connector off and no fuel squirted out. The filter look like its partially empty of fuel so my thoughts are pump or relay?
Any ideas. I know my way around cars but not so much the Audi. I'm not even sure which relay it is. Can I get to the pump myself ?
Thanks in Advance.
Old Jan 15, 2014 | 05:09 PM
pa4ul's Avatar
hmm not sure if the pump is in the same location as the 1.8 but check in the trunk under the floor mat. There should be two small doors on the floor. The pump is located under there.
Old Jan 16, 2014 | 01:44 PM
markymarc's Avatar
If the key was out and the pump kept pumping/running...something didn't tell it to shut off...but disconnecting the battery cut power to the whole car and it stopped, correct?
And now it's not pumping fuel at all, so, I'm GUESSING, it may be a bad relay....
Your fuel pump in your car is in the tank...which is kind of a pain to replace....
Check your modules and relays first, then go from there...if the module or relay got wet or waterlogged for awhile, it could cause all kinds of havoc....
Have you scanned for codes?
Old Jan 17, 2014 | 06:44 AM
tweety's Avatar
Thanks. I don't have a scanner and as it turns out I've been a bit of a dick. My car is a B7 ! So I've posted this in the wrong place.
Its still not pumping so I think its probably the relay. Question is on a B7. Which one. I've managed to flatten the battery trying so its on charge.
Thanks for the help. Even though its in the wrong place !
Old Jan 17, 2014 | 07:15 AM
markymarc's Avatar
Your fuel pump is still in the tank and it's a low pressure pump.
The fuel pump relay is 618 or 614 I Think..... 5 pin, I believe, and if i remember correctly and its the front relay under the ECU, under driver's side dashboard...I don't know which one it really is, you'll have to google it....or pull it out.
Old Jan 17, 2014 | 08:59 AM
tweety's Avatar
Thanks. Got the dash off. I'll take a look once its charged. I've googled but nothing conclusive came up so i'll search again.
Old Jan 17, 2014 | 05:12 PM
markymarc's Avatar
Dave's
Apr 27, 2013 05:14 PM
DanaB6
Apr 26, 2012 07:09 AM
gaberossi
Jul 20, 2009 08:26 PM
chancebuttars
Jan 6, 2008 09:31 PM
notKreative
Jul 19, 2006 01:42 PM
