noob needs help
Old Sep 16, 2012 | 09:32 PM
olstyn's Avatar
Originally Posted by Clos2010
Dealer said that was causing a code to come up for the brake booster, $150 replaced at Audi dealer for 5min job lol
OUCH - they screwed you HARD on that one. That's less than $5 in parts, including screw-down hose clamps to replace the crappy one-time ones from the factory. Those check valves are less than $1 each from usplastic.com, and as you said, it's 5 minute job.
1/4" PP Standard Check Valves | U.S. Plastic Corp.
Old Sep 17, 2012 | 04:43 AM
spikezone2004's Avatar
Did you happen to fix your problem? I have the EXACT same problems with you and i have been trying to figure it out for a while, i feel like i have some loss of power too doesnt feel as punchy as it use to be at higher speeds. Any ideas?
Old Sep 17, 2012 | 06:30 AM
euronoob's Avatar
no solution yet. next chance i get to work on it is tuesday. ill let you know!
Old Sep 23, 2012 | 05:03 AM
euronoob's Avatar
well i got a new speed sensor in and no longer have the EPC/limp mode problem. but now the scanner tells me my MAF sensor is bad. got a new one and hopefully will change it out tomorrow.
phila1776
Dec 12, 2007 12:38 PM
sheatswitch
Dec 6, 2006 09:02 PM
Euroluv
Nov 14, 2006 09:05 PM
TheAudioGuru
Nov 1, 2006 03:35 AM
AdLucem
Mar 9, 2006 04:29 PM
