Oil Change Question
Old Aug 12, 2009 | 12:55 PM
  #21
timmay074's Avatar
i just did my change today using mobil 1 5w-30 and the m1-301 filter
first time i ever did an oil change on my own car and i was pleasantly surprised with how easy it was, biggest pain for me was putting in the plastic skid plate under the car again haha
Old Aug 12, 2009 | 01:45 PM
  #22
pa4ul's Avatar
I use castrol sythentic recommended by alot of good mechanics. Even though audi says to use mobile. MAke sure u replace ur crush ring on ur oilpan or it could develop leaks in the near future.
Old Aug 12, 2009 | 02:18 PM
  #23
timmay074's Avatar
crush ring? i've never heard of that before.
the only thing i could imagine it being is the washer that goes between the screw and oil pan?
Old Aug 12, 2009 | 06:05 PM
  #24
pa4ul's Avatar
Yes sir thats it. Some people have the problem of the washer warping and eventually leading to a small leak at your draining point. not a must need the first time u change ur oil but always keep an eye on it when u change it.
Old Aug 12, 2009 | 08:09 PM
  #25
timmay074's Avatar
good ****, thanks for the heads up.
Old Aug 12, 2009 | 10:39 PM
  #26
pa4ul's Avatar
roger sir
Old Aug 14, 2009 | 10:09 AM
  #27
Grapeel01's Avatar
Sorry to dig up this old thread.
Many of you have said that putting back on the undertray is a pain. I usually leave mine off as I oil change twice per year. Apart from some minor noise silencing does it serve any other function?
Thanks
Old Aug 14, 2009 | 10:41 AM
  #28
timmay074's Avatar
mainly its to protect the oil pan from debris and anything else that you might hit, say a curb while pulling into a parking spot.
although i dont know if this is true, ive seen a few people say they have gotten noticeably better fuel economy because of it too, but i have no clue about that
Old Aug 14, 2009 | 01:50 PM
  #29
Midniteoyl's Avatar
Some things the belly pan does:
Helps protect the engine bay
Helps radiator efficiency by keeping air from rolling around under the bumper
Helps with cooling by speeding up airflow under car, lowing air pressure and accelerating the air out of the engine bay
Same effect helps hold car to road at speed
Smooths airflow under car for reduced drag
jamezz23
Jan 3, 2011 10:21 PM
xcuter
B7 Models
Jul 30, 2008 09:51 AM
badjoke
Nov 6, 2007 01:31 PM
xbrian87
Sep 7, 2006 12:29 AM
abacab
May 31, 2005 10:35 PM
