Radiator fan still runs after shutting down!
Old Aug 8, 2014 | 05:04 PM
Exuberantt's Avatar
Default Radiator fan still runs after shutting down!
Hallo Folks. I've been driving Audi A4 S4 2002 since nine months ago. I've changed so many things from the car from timing belt to water pump and most recently a month ago o-ring coolant flange. The car was and still is running perfect.
Except this recent behavior it started a week ago. The radiator fan stays on after I shut off the car. It happened once, I let it run for about five minutes. When I saw it was not shutting down. I started the car and shut it off. Then it was off! A week later, tonight the same thing happened. I tried to let it run for ten minutes to see if it's gonna shut down itself but to no veil. I did the same procedure I did before to have it shut. The coolant level is perfect at max, the car does not overheat according to the temperature gauge. It stays in 50*c instead of the normal 90*c. When I restart it the radiator fan shuts and the temperate gauge goes to normal 90*c.
There are no dashboard warning lights. I shut it by restarting the car cause am afraid to be left stranded by a drained battery. The radiator fan will surely drain the battery if left like that.
What is it telling me to know before the real problem occurs so that I can get it fixed. Any experience shared will be appreciated! Thanks in advance! Cheers
Old Aug 20, 2014 | 01:07 AM
Exuberantt's Avatar
Got the temperature sensor changed. It seems it had fixed my problem. It has been a week and everything seems normal.
Thanks for nothing!
TonyDemin
Feb 6, 2024 02:11 AM
influentialsonny
Nov 13, 2013 06:30 PM
Got01A4
Sep 18, 2010 12:25 AM
