Replacing temperature sensor, clip facing wrong direction
Old Feb 19, 2012 | 04:35 PM
triplerr's Avatar
Default Replacing temperature sensor, clip facing wrong direction
My temperature gauge on the dashboard never moves and I've been losing a lot of engine coolant over the last few months. Based on what I've read, these sensors tend to go out a lot. I was able to remove the sensor using this post http://www.audiworld.com/tech/eng66.shtml. However, the problem I came across is the retaining clip. The author made it sound like his clip was removed going towards the back of the car. My clip was seated toward the front, ie I had to pull the clip off the sensor housing by moving the clip toward the front of the the car with a screwdriver, this was an absolute bitch to accomplish. I dont see how I can reseat the clip since there is no room for your hands let alone leverage. Question, can I reseat the clip facing the opposite direction, pushing the clip back on so the bottom of the U is pointed at the back of the car instead of how it was OEM seated, with the U facing the front of the car.
Old Feb 19, 2012 | 05:02 PM
M5S5's Avatar
Tech Certified
Yes. it can go in the opposite direction. Replace clip & o-ring when doing the sensor.
Old Feb 20, 2012 | 11:19 PM
ImTheDevil's Avatar
And make sure you get the old o-ring out before seating the new one on the sensor.
sleek55044
May 17, 2012 02:27 PM
Theiceman
May 2, 2012 10:45 PM
OKIE
Nov 7, 2009 02:19 AM
kwaskow
Jun 2, 2008 10:39 PM
johnstef
Dec 1, 2007 05:31 PM
