transmission question
Old Apr 20, 2008 | 02:11 PM
rikan0569's Avatar
Default transmission question
im a new member and im having alil problem, the check engine lightis turning on and offso the mechanici took mycar tosaidthe problemwas friction between the gearsand to put alubricating transmitiontreatment but i dont know which one would be good for an audi a4 1.8t 2004 auto
Old Apr 26, 2008 | 01:08 PM
AudiTech616's Avatar
Default RE: transmission question
Can you post the codes?
Old Apr 26, 2008 | 08:04 PM
audiprotein's Avatar
Yep, get the code and it is going to be much easier for u and ur mechanic.
Old Apr 26, 2008 | 08:24 PM
auditech79's Avatar
No oil additive is gonna cure a check engine light, friction modifiers only aid shifting the transmission and reduce chatter in the torsen differential. Its most likely a torque converter fault, or emmisions related.
Old Apr 30, 2008 | 12:02 AM
rikan0569's Avatar
the codes are p0378(timing reference high resolution)b0887(Tem transmission control modual powerrelay control cicut high) u311a(dont know)u2200(dont know)the mechanic dint know what the lasttwo codes were
Old May 3, 2008 | 02:27 PM
rikan0569's Avatar
any sugestions, Im I going to need a new tranny ??
whitey
Sep 25, 2009 01:19 PM
iNsaNiA
Jan 13, 2009 09:39 PM
brimhall99
May 10, 2008 10:30 AM
armani1608
Feb 21, 2007 03:24 PM
adoraim
Jan 5, 2007 03:27 PM
