washer fluid bottle
Old Mar 20, 2011 | 09:47 PM
caseyg92's Avatar
Default washer fluid bottle
Is there two washer fluid resivours on the b6 a4? becasue i have a leak and is washer fluid but i dont see it coming out of the washer fluid bottle. It leaks out through the fog light on the drivers side. any help?
Old Mar 20, 2011 | 10:45 PM
BesI's Avatar
yes there is and I think that's for the headlights and if you take the cover that's under the car you'll be able to see it.
Old Mar 21, 2011 | 02:48 PM
pa4ul's Avatar
there is only one tank. The place you are leaking from is the headlight washer line. If u pull ur headlight and peak in and under you will see the lines. Alot of times just retighting the plastic line will stop the leak. and you wont be able to see the lines from under the car either.
Old Mar 22, 2011 | 11:47 AM
caseyg92's Avatar
so just take the headlight out and look and i cna see it?
Old Mar 22, 2011 | 05:55 PM
Audi Tek's Avatar
Tech Certified
More often than any is the jet or washer cylinder for the headlight that leaks
Old Mar 23, 2011 | 11:52 AM
pa4ul's Avatar
u should be able to pull the headlight out and stick your head in their and look underneath the headlight tray. I just squeezed where the connections are and it stopped the leak for a month or two then it came back. now i run with no washer fluid unless i run down to the beach
Old Mar 23, 2011 | 03:53 PM
MKE_Audi's Avatar
I have a leaking headlight cylinder on passenger side of my 2003 A4 quattro. What is the best place to get a decent priced replacement? I've had some say that is a safe part to go the eBay way. Part number anyone?
mcanedo92588
Jul 1, 2013 11:27 PM
Velox65
Sep 28, 2011 01:09 PM
realslfan
Aug 9, 2011 04:12 PM
slee22
Jan 23, 2008 01:56 PM
MiniSpdRcr
Nov 9, 2006 01:22 AM
