2006 A4 2.0t - starts wont run
Have the 2.0t which as having issues while my wife was driving with it jerking and stalling at stoplights - she was on vac with the family so I had her put LUCAS in a couple of tanks and it got here home from Florida
BUT - now the car will start but then immediately die - the code list was long - but the easyones were misfires on all 4 so I did the coil packs and plugs - did not work
SO - Im asking for a little help - pulled the hose the throttle body and sprayed starting fluid in while starting and go results - Im thinking fuel - easiest first - fuel filter - still same results
Next fuel pumps - one in the tank - one on the back of the engine - what is the eaiest way yo check which might have failed???
JPJM
, P0171(sys too lean), P0300, P0301, P0302, P0303, P0304 (misfires), P0507 (idle air), P0089 (Fuel Pressure) (sys
JPJM
JPJM
JPJM
I changed the low pressure fuel pump in the tank. Didnt fix the issue. Also the fuel filter was changed.
It still starts and immediately shuts down. I put a guage on the fule rail and turning the key to on - I get 74 psi
When you start the car it jumps up to 82/84 psi.
Does anyone know what the number should be?
JPJM
JPJM
DermoviAdika
Jun 6, 2013 12:21 AM
