2006 a4 won't start
Old Jan 24, 2012 | 07:44 PM
zmo11's Avatar
Default 2006 a4 won't start
I recently got an 2006 audi a4. 83,000 miles. I bought it from an insurance company and had to put a new rear clip on it. When I first started driving it the radio worked, but the CD didn't and neither did any of the steering-wheel controls. One day it all started working (except cruise control). Then just yesterday it was running fine with about half a tank of gas, and right before I shut it off for the night the service light came on. This morning I went to start it, and it took longer then usually...but started. Service light was still on, and it now says I am empty. Car ran for about thirty seconds before dying. I put a gallon of gas in it and the engine cranks and cranks but won't start. I checked all fuses, and disconnected battery, but I don't know where to go from here. Any ideas?? Also the "oil sensor" light has been on since i started driving it about 10 days ago. Thanks
Old Jan 24, 2012 | 08:31 PM
jagtoes's Avatar
I assume you checked to see if there was any oil in it. You'll need to go back to basics. Check for spark and fuel. Go from there.
Old Jan 24, 2012 | 11:35 PM
zmo11's Avatar
Yes, I checked oil, levels are fine. But before this happened, I was gonna change it this weekend.
Old Jan 25, 2012 | 09:27 AM
rhodes991's Avatar
Sure sounds to me like you have a short in the wiring somewhere. Could be damage from the accident that wasn't spotted during the repair. You seem to have a lot of potential electrical issues (oil light, steering wheel controls working then not working, fuel gauge, etc...).
Also, do you hear the fuel pump priming when you open the driver's door? If it isn't fuel won't make it to the engine. Could be an additional electrical issue.
Good luck.
Old Jan 25, 2012 | 07:11 PM
Audi Tek's Avatar
Tech Certified
Yea, I have had my fair share of accident rebuilt cars....
This is best left to an Audi Technician.... thats why i have seen so many of them.
Because you need to scan the car. Document all faults. Delete all the faults. Check your fuel, spark, and compression.
Then scan it again and see what faults return. Then you need to group the fault into "like or shared" systems and tackle them individually.
Like Rhodes said..... Pinched or broken wires are common in accident cars and are ALWAYS overlooked by body shops.
So with an experienced technician that knows where all the sensors and modules are in your car.... where the harnesses are run inside the car makes it alot easier.
Sometimes i get my fair share of headaches chasing problems in these cars too.
But you want a shot in the dark. A hit from behind..... I start with the fuel pump. You need to supply the two fat terminals 1 - 4 with power and ground. Remove the fuel line on the engine and put it into a bottle. When power is supplied pump noise should be heard and fuel should begin to fill the bottle.
I would doubt spark plugs or coils are your issue unless a ground is pinched or broken, but since the accident was in the rear, i would say less likely.
So stick to fuel for now.
Old Jan 26, 2012 | 02:22 AM
zmo11's Avatar
I'll start with the fuel then. If I can't figure it out from there I will leave it to the experts. However as far as the priming is concerned it is still working, or at least it sounds like it is. Thanks again everyone, anyone else that has ideas I am more than happy to listen, and I'll be sure to update if any diagnosis comes along
Angelisus
Feb 16, 2017 06:53 PM
AAndy
B7 Models
Dec 8, 2014 03:25 AM
ruffryd
Jun 11, 2014 09:23 PM
ntfaase
Oct 9, 2013 11:20 AM
Jim Cavoto
Nov 27, 2011 07:08 AM
