2008 Audi A4 P2181 error reset
Old Jan 26, 2015 | 08:04 PM
kangluo's Avatar
Default 2008 Audi A4 P2181 error reset
Hi, I am new to this forum and did Google to get here. I have read tons of threads regarding P2181 coolant system warning here. Here is my situation. My 2008 Audi A4 had this warning popup on 01/02/2015 when Austin got very cold. I just got a scanner to read and erase the code since the engine temperature seems normal in the next several days. However, on 01/12, 01/22 and 01/26, almost the same time, the CEL came on again after I erase the error for each time, the scanner gave me below message:
P2181 01/02
P2181 P 02/02
Is this a repeating P2181 warning happening on these days or just I didn't reset/clear the error correctly?
If it is repeating, I would like to replace the thermostat, but I want to confirm before I open the hood.
Thanks
Old Jan 27, 2015 | 11:16 AM
KingWulfgar's Avatar
It's likely your thermostat. Is your engine temp "wandering" or pegged in the middle? Your engine temp may be fine, but if it's taking too long to get to temp (stuck open), it will throw that code. It could be the coolant temp sensor and that's a cheaper fix to try first if you want, but on mine, I did that and the code came back. Replaced the t-stat and it's been gone for a while now.
Old Jan 29, 2015 | 07:37 PM
kangluo's Avatar
Yes, it does wander between the middle and 3/8 position for the first 20 minutes. Does it confirm the thermostat needs to be replaced?
Old Jan 30, 2015 | 09:23 AM
I don't know about confirmation, but yes, that is highly suspect of a bad thermostat. That's what mine was doing. It's a medium-skill DIY (lots of write-ups around). I think I paid somewhere around $300-350 at my local indie shop to have them do it. Now, it climbs straight up to the 12:00 position in about 5-7 minutes and pegs there.
Diarmaid
Apr 21, 2013 12:15 AM
m1e2bran3
B7 Models
Oct 29, 2012 08:25 PM
Dyfan001
Aug 28, 2012 05:14 AM
Diarmaid
Jan 31, 2011 08:43 AM
BraincellGenocide
B7 Models
Jan 20, 2011 02:36 PM
