AC won't blow cold air
Old Jun 29, 2012 | 05:25 PM
iceicec's Avatar
Default AC won't blow cold air
Hey Guys, I have a 2007 A4 2.0T quattro and the AC stopped blowing cold air. Any ideas on what it may be?
Any help would be very much appreciated.
Old Jul 4, 2012 | 10:02 AM
Audi Tek's Avatar
Tech Certified
A/C systems are tricky and its never 1 thing.
You have to run a full diagnostic on the whole system and to do that you have to know A/C fundamentals and operation to know which part isn't working.
Its a job best left for a certified person, Not necessarily a dealer but atleast an A/C shop.
Most common cause is a leak..... and usually from the condensor because its exposed and usually gets hit with a rock or something
Old Jul 4, 2012 | 12:03 PM
rhodes991's Avatar
Check you fuses and is none are blown then take it in to a shop. If it is low on freon then the compressor will stop engaging and may just need a recharge. If there is a leak they can locate it and tell you how much to fix. Worst cas eis the compressor went out and that will cost lots of $$$$ to replace.
Old Jul 6, 2012 | 02:32 PM
Jeff-AudiUSAParts's Avatar
Former Sponsor
If the compressor runs and circulates freon in the system, look in the sight glass which is usually on the receiver drier. If you see bubbles in that sight glass then there is air in the system and that indicates a leak. That's a sure sign way of knowing an O ring or hose, seal on ac compressor, something is leaking.
Bobbydigital2012
Aug 2, 2009 06:11 PM
AudiStyle101
Apr 24, 2006 03:24 PM
greves
Mar 30, 2006 02:20 PM
seth1005
Aug 15, 2005 05:53 AM
