Cam follower / PCV valve ?
Old Mar 14, 2011 | 12:52 PM
  #31
2wdBlazer's Avatar
Looks as if you man handled something to snap that sensor. If things are in the way I always disconnect them. Not sure how that happened but i am sorry. That is the best PCV out there and will never fail you. Take a fresh look at it and try to fix it and get it on. Then tackle the sensor. It should not be hard to repair.
Old Mar 15, 2011 | 08:45 AM
  #32
rmacgurn's Avatar
yes I did get it in yesterday, by removing the nipple then inserting the hose, then installing the nipple with the 4 screws lose to allow the plate to tilt to get the nipple in. i was able to tape up the sensor, now i just need to be sure which one and part number to order in US to send here as the dealer will not help me at all since i have a gray market car....
if you know this sensor, or an exploded view showing the parts in this area that would be great. thanks for you help and advice.
rick
Old Mar 15, 2011 | 11:51 AM
  #33
2wdBlazer's Avatar
I do not have a book or CD. Maybe someone can chime in on that sensor for you. Does the car run now?
Dont worry about the DV either as it is a piece of cake.
Old Mar 16, 2011 | 09:05 AM
  #34
rmacgurn's Avatar
yes the car runs fine, however some back tape is holding the sensor connector and broken piece to the brass base, but i will use some silicon this weekend. borrowed some jack stands and a floor jack to put the front up to do the DV just hoping don't need something i don't have in the middle, like gaskets or o rings or special tools....thx
rick
ps. i ordered a VW/Audi thrust sensor as someone on Audizine said that is what its called and of course the VW dealer didn't have one and Audi wont sell me parts.
Old Mar 16, 2011 | 02:11 PM
  #35
2wdBlazer's Avatar
Nothing special but the DV needed. It May use Hex or Torx bolts though as I can't remember.
Here is a DIY on a GTI (SAME). Don't break the sensor clip. you seem to be rough on sensors. I did mine on car ramps as that is much less work than jack stands.
http://golfmkv.com/forums/showthread...85#post1686085
Old Aug 4, 2011 | 04:58 PM
  #36
e4c's Avatar
e4c
Originally Posted by rmacgurn
i can see now how the 2pc kit would be much easier to install, but here are two photos to show you the obstruction blocking the install of the hose, and broken connector on some sensor, water temp? no idea what i broke, but i cannot recommend BSH for this mod to anyone who like me is just ok doing DIY's per instructions.
ooooo i almost did the same thing with that sensor.
then my cousin broke the holding clip off it trying to take it off to move it out of the way....AFTER i told him not to touch it...
tied it down with electrical tape, which is pretty lame, but its been working so far..
sorry to open this back up months later but i just had to share that...
afat08
B7 Models
15
Nov 7, 2016 12:54 PM
mezonesxbox
B7 Models
Jun 23, 2014 06:03 AM
bandmax
B7 Models
Jan 19, 2011 11:09 PM
pb_beaker
B7 Models
Jul 13, 2010 11:37 AM
diggs
B7 Models
Jan 27, 2010 04:22 PM
