High Pressure Fuel pump
Old Mar 16, 2015 | 06:37 PM
Amybc96's Avatar
Default High Pressure Fuel pump
B7 165000 miles. And a whole bunch of codes.
My fuel pump was taken out and the cam was checked out and was fine. Fuel pressure was below recommendation. Pcv valve was replaced and most codes went away.
After a while I had a "Fuel door open " error
For the past few years I have had a slight rev pulsation at low revs which goes away when slight gas is applied.
I have a new pump on the way but is this the problem?
I searched for threads on how to do this but only found "Under the seat" threads.
Any help would be great.
Cheers
Old Mar 17, 2015 | 09:07 AM
KingWulfgar's Avatar
Honestly, the problems sound unrelated. I'm not sure what the "fuel door open" error is--can you be more specific with the code?
Do you have an automatic transmission? The pulsing RPMs sounds more like the torque converter problem (search the forum, there are several threads including one with the Audi TSB about it in the thread). I have it and it's been several years. As long as it doesn't get worse or leave me stranded, I'm not inclined to pay to fix it. It's more of an annoyance.
Old Mar 19, 2015 | 10:02 AM
Audi Tek's Avatar
Tech Certified
Yea we need the faults your seeing.
The in tank fuel pump is a common failed component so it's a feasible diagnosis
Old Nov 30, 2017 | 02:49 PM
B5b6b7dailys's Avatar
Cheers
Hello I'm having same issue with my 2005.5 b7 2.0t I replace cam follower it was not damage that bad I have pics did not see any damage on hpfp so I replace follower and put it back on it ran alot better for few weeks and started it this am and died wont start im wondering if anyones had promblem with just the hpfp going bad?
Foxlovescars
Jan 3, 2015 04:51 PM
Country Grammar
Nov 14, 2014 11:25 PM
joshlowe
Jan 23, 2014 01:41 PM
FV49
B7 Models
35
May 15, 2011 03:20 PM
Country Grammar
Jan 24, 2008 08:11 PM
