Quick Q on timing belt
Old Nov 1, 2012 | 07:31 PM
jokie's Avatar
Default Quick Q on timing belt
Here's a quick question on timing belt change: is it necessary to remove the car's whole front section (service mode) to perform a timing belt change? Or is it possible to perform the change without putting the car in service mode?
Thanks
Old Nov 2, 2012 | 05:16 PM
A4Cragman's Avatar
As far as I know, it has to be in full service mode. I'm sure it *could* be done (don't stick me to it, I've never done a tbelt myself; basing this statement by logic) but it would be far more of a pain to attempt it and probably take you twice as long as if you just took the extra time to put it in full service position since you have to make sure the belt is lined up EXACTLY on the right teeth of the cams; being off by even one tooth will screw you, and trying to line that up without being able to look at it properly will do nothing but make you crazy.
Old Nov 2, 2012 | 08:18 PM
jokie's Avatar
Thanks for your input. Exactly what I was thinking. I just needed reinforcement. Thanks!
Old Nov 2, 2012 | 08:49 PM
Audi Tek's Avatar
Tech Certified
i have no idea what you mean you say service position and full service position...
There is only service position and completely removing the entire lock carrier.
All you have to do is unbolt it and let it hang forward. It will give you about 6 inches of space. Which is enough to do the job
billymac122
Jan 1, 2012 08:59 PM
Cris_A
Oct 3, 2010 11:36 PM
peterbr17
Oct 28, 2009 06:09 PM
QuickQuattro
Aug 5, 2007 08:48 PM
Lmohaxx
Apr 3, 2006 12:21 PM
