Ticking Noise, pressure leak
Old Apr 9, 2012 | 09:57 PM
AudiA4bosnianstyle's Avatar
Unhappy Ticking Noise, pressure leak
I have this ticking noise when car is running at idle, and it got lil worse about two days ago, also when I pull oil dip stick or stick w.e you call it i have good intake suction and engine starts to choke, car sometimes runs normal idle speed right under about 1000rpm, but now its starting to go up to 2000rpm and goes up and down, I am not sure what is couse of this, any ides or what to check, what to do, I also took video of it so you guys can hear it
2007 Audi A4 2.0t Ticking Noise - YouTube
2007 Audi A4 2.0t
90k miles
Old Apr 10, 2012 | 08:18 AM
jmarshall098's Avatar
Did you checked the engine timing? And its normal for an engine to choke when you push that dipstick again after pulling it. When you pull it, the gases escape through blow by.
Old Apr 10, 2012 | 08:46 AM
Damaniac311's Avatar
Are you sure the ticking isn't just the fuel injectors? FSI engines do sound "diesel-y."
Old Apr 10, 2012 | 09:51 AM
Ericcg82's Avatar
The fluctuating RPM at idle make it sound like bad PCV valve...
Old Apr 11, 2012 | 08:13 PM
B7Night's Avatar
Check with the dealer to see if your car is part of the service action that was started recently. Audi will replace the PCV valve and related plumming free of charge.
Old Apr 18, 2012 | 02:41 AM
lewd's Avatar
I have the same ticking noise on my 08 A4 Quattro. OP, did you figure out what the cause is? Thanks,
rahip4567
B8 Models
Nov 13, 2019 04:04 AM
me76brooklyn
Apr 25, 2011 04:24 PM
nlnfns
B7 Models
Nov 19, 2010 06:09 PM
Jeffrey
Aug 15, 2010 12:00 AM
mcmro
Apr 26, 2005 08:47 PM
