Water temp
Old Jul 17, 2016 | 04:24 AM
grahamjf's Avatar
Default Water temp
Just bought a A4 b7 2.0 tdi 2005
silly question but where should the water temp sit, mine sits just above 50 even after 2 hours of driving. Some times drops back to the 50
But when i select hot air its gets hot.
Is it normal sitting so low down?
Thank you in advance
Old Jul 18, 2016 | 03:21 PM
KingWulfgar's Avatar
Just above 50 what? Degrees? Don't know much about the TDI, but if your water temp doesn't come right up to midline on the gauge (200-ish degrees) as it warms up and stay there solid, your thermostat is probably bad. Mine would sit at about 10-11 o'clock and wander up and down a bit. Thermostat.
Old Jul 19, 2016 | 10:12 AM
rhodes991's Avatar
Mine sits right at noon on the gauge (right in the middle) after warm up.
Old Jul 21, 2016 | 03:35 PM
imaudi5000's Avatar
Yea 50 degrees Fahrenheit? My 2.0T had a slightly stuck open thermostat and wouldn't reach full temp, which for me is 200 Fahrenheit. Definitely need to check your thermostat or coolant temp sensor....
zer0vette
Jul 21, 2010 10:30 PM
kbrookst
Oct 24, 2009 06:37 PM
danmcc86
Feb 12, 2009 11:49 PM
jankerfun
Nov 12, 2007 01:47 PM
