87 5000 CD Turbo Starting Problem.
Old Nov 20, 2005 | 04:41 AM
  #31
mcozea's Avatar
Default RE: 87 5000 CD Turbo Starting Problem.
it worked. the fault codes are 4444 (no problem detected) and i really seem to get better mileage. but i still cant get over 1 bar boost
Old Nov 20, 2005 | 11:43 AM
  #32
kakarot's Avatar
check the wastegate, it is bolted directly to exaust manifold, paralel to turbo. there is a spring inside, as it gets old it tends to lower its K constant. (gets softer) buy NEW spring if you can and replace if posible. or new wastegate. or add extra spting.
here read this: http://www.homestead.com/Ben_Swann/boostin.html
ALSO check for boost leaks. all the hoses. if it makes a whoosh sound.
Old Feb 16, 2006 | 10:23 PM
  #33
mcozea's Avatar
So ive pretty much solved the problem wit boost but i still have the issue of it not starting when the engine is cold. or when the engine is over 75 degress C. its really anooying as i have to try and start it once then wait 20 seconds, try again, mayb get lucky and have it start. if not i have to do it like 4-7 times total before it starts. anyone know why this would happen?
ljbrandt
Sep 2, 2008 08:30 PM
alticjob
Mar 30, 2008 02:48 AM
slowandrugged
Feb 19, 2007 05:59 PM
thefox
Jan 19, 2007 03:15 AM
cherriesw
May 4, 2005 01:17 AM
