Audi 90s washer pump
Old Jun 20, 2009 | 12:07 PM
kaodixflow's Avatar
Default Audi 90s washer pump
Hi Guys
I have a 1994 Audio 90s and the windshield washer fluid reservoir leaks when I pour water in it. The washer pump doesn't work either and probably needs replacing. How do I get to the washer pump? Is it in the bottom of the reservior? I probably have to take the inside fender well out right?
Thanks
S
Old Jun 23, 2009 | 03:37 PM
NH_USA's Avatar
I don't know about the 94 90 but the pump is at the bottom of the reservoir. Why not se eif you can get a used reservoir with pump from a junk yard. Used Audi stuff is available from Shokan in PA and Force Five in Concord NH
Old Jun 25, 2009 | 07:58 AM
salleuxe's Avatar
Default Water pump
I have a100 87 year. I had problem once with my washer system. I thought pump didnt work, no sound, no anything. Like dropped dead. When I checked, it was run out of water, so I pour a mixture of water and cleaning solution but it didnt work again. Then I took a needle and put it into the nozzles on the hood for I supposed that pump somehow sucked in "mud" from the reservoire and thus blocked the nozzles. I was right. After I cleaned the nozzles it was working perfectly. Try that. Maybe somewhere something is blocking way out for the water so the pressure is released somewhere else.
Jeffla
Nov 25, 2010 10:09 AM
gabeguimaraes
Mar 29, 2009 01:24 PM
millenia
Dec 3, 2007 11:05 PM
a3square
Feb 21, 2007 08:17 AM
Willfulone
Jan 26, 2005 01:58 PM
