camshaft position sensor
Old Jul 9, 2006 | 04:02 PM
cabrioman1995's Avatar
Default camshaft position sensor
Hello again. On the no start problem I am having. I pulled the trouble code and got 2113 camshaft position sensor. Any tests for the sensor before replacing it or anything related to the camshaft positionj?
Thanks in advance
Old Jul 9, 2006 | 04:33 PM
techbod's Avatar
Default RE: camshaft position sensor
camshaft position sensor (CMP)has a 3 pin multi plug,
checking the ground/earth
ensure ignition is off,
disconnects CMP multi-plug,
check resistance between pin 3 and ground,
resistance should be zero..
checking voltage supply
switch ignition on,
check voltage between pins 1 and 3,
voltage should be 9 V min..
signal checking
do not disconnect multi plug access pins from the back of the multi-plug,
connect LED test lamp between pins 1 and 2,
briefly crank the engine,
check the LED is flashing
Javen
Apr 6, 2015 06:26 PM
Peterhopson84
Aug 20, 2013 09:57 PM
skeener
Dec 23, 2009 02:39 PM
jstryz
May 14, 2009 01:07 PM
