Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
B5 A4 Chipped ECU
Old Oct 3, 2012 | 03:57 PM
Erica4Mese's Avatar
Question B5 A4 Chipped ECU
I have a 2000 b5 a4 and am looking to buy a GIAC chipped ecu. If I buy the already chipped ECU from another 2000 b5 a4 would they be compatible without having to re-chip the ECU? Also, I am looking to get a downpipe. Would I have to get a chipped ecu for my car with a downpipe?
Old Oct 3, 2012 | 07:48 PM
ImTheDevil's Avatar
Yes you can use the ECU and no, a downpipe doesn't require a specific tune.
Old Oct 8, 2012 | 03:10 PM
Erica4Mese's Avatar
Question
I just have to make sure it came off of a 2000 b5 a4 ? Does the ecu have to be from a manual as well ?
Old Oct 8, 2012 | 04:04 PM
ImTheDevil's Avatar
It needs to come from an A4 with the same engine code as yours. If you have access to Vagcom, you can recode it to work with your drivetrain (ie, change it for use in a manual Quattro, front drive auto, etc) - there's a quick recode procedure in the DIY section.
Old Oct 9, 2012 | 12:30 PM
Erica4Mese's Avatar
Question
This is probably a dumb question , but what is an engine code ? Also , cant I just get the ecu from a fwd manual to avoid all of that bs ?
Old Oct 9, 2012 | 12:37 PM
ImTheDevil's Avatar
Yes, getting an ECU from another fwd manual makes it easier. My point was, you don't have to - another ECU can be recoded to work in your car. Engine code is stamped on the small rectangular tong on the front driver side corner of the head. Should be AWM I believe - these designators are used to differentiate between engines. Early 1.8Ts were AEB engines. I believe yours should be an AWM.
Old Oct 10, 2012 | 03:04 PM
Erica4Mese's Avatar
Question
So the letters marked on the head is the engine code ? Im pretty sure it was AWM . So if I get an ecu from another 2000 b5 a4 fwd manual with the same engine code I can just plug it in and go ?
B5Project
Feb 16, 2009 03:31 PM
fumoazul99
Jul 19, 2008 07:15 PM
slamer32
Sep 25, 2006 03:32 AM
Audinam
Jun 13, 2006 02:51 AM
Spdrcr7882
May 23, 2006 04:35 PM
