Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
Cheap power, Diode, MBC, and Boost gauge install
Old Mar 21, 2008 | 11:36 AM
  #131
zippy_gg's Avatar
Default RE: Cheap power, Diode, MBC, and Boost gauge install
Would the diode mod work on my 2000 A6 2.7t?
Old Apr 3, 2008 | 01:20 PM
  #132
texasboy21's Avatar
finally installed my podi and boost controller set at 11-13 psi spike and hold about 10psi. It runs a little stronger but i cannot wait to get this diode soldered in. Until then will i need to add fueling or timing?
barrett
Old Apr 16, 2008 | 12:10 PM
  #133
M and N's Avatar
cincytt how or what do i need to do to get rid of the blow through dv set-up cause honestly i hate it, not to mention it put unneeded stress on the turbo causing compressor surgeand makes them **** long before there due, and i say this cause i have actually put a k03s turbo on a honda and have over 180k on the snail with no issues at all, but hear about some of them dyingway to soon in life, so i guess what im getting at is can it be change with out a ton of money and not getting a cel or unliked drivability issues
Old Apr 17, 2008 | 12:41 AM
  #134
cincyTT's Avatar
I'm make believe
Who the FU(k moved this here?!!?!?
ORIGINAL: zippy_gg
No
Old Apr 17, 2008 | 12:42 AM
  #135
cincyTT's Avatar
I'm make believe
ORIGINAL: texasboy21
barrett
You will be fine with no adjustment up to 18psi. After that you should check vag logs and add fuel if needed
Old Apr 17, 2008 | 12:45 AM
  #136
cincyTT's Avatar
I'm make believe
ORIGINAL: M and N
The turbos die becuase of not letting them cool, over boost them, or some other strange mishap like wastegate nut comes loose or something gets sucked into the intake. They are great turbos and will easily last over 100k miles if taken car of. The dv system has nothing to do with it, they flow enough as is
Old Apr 17, 2008 | 01:26 AM
  #137
M and N's Avatar
ORIGINAL: cincyTT
ORIGINAL: M and N
that did not anwser the question, i know they last longer then 100k but what i want to know is the way to eliminate the blow through dv set-up
Old Apr 17, 2008 | 02:08 AM
  #138
cincyTT's Avatar
I'm make believe
I seriously have no idea what you are talking about. either be clearer or i can not help you. The stock system/design works fine for the stock turbo.
Old Apr 17, 2008 | 11:40 AM
  #139
zippy_gg's Avatar
ORIGINAL: cincyTT
ORIGINAL: zippy_gg
No
Thanks Cincy! I just got my APR chip so I guess I will get the extra boost that way!
Old Apr 17, 2008 | 01:22 PM
  #140
M and N's Avatar
what was not clear, i asked is there a way to eliminate the blowthrough dv system. and if i just vented it to the atmoshere what would happen in doing so
