Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
Cheap power, Diode, MBC, and Boost gauge install
Old May 31, 2011 | 02:52 AM
  #191
sergey123's Avatar
Default audi ecu go in to limp mode
hi i got an 1999 audi a4 and i belive there is no MAP sensor and my ecu go in to limp moode where it get ower 10 psi boost and i would do a Diode to control the voltage to send ecu low voltage so it wount go in lipm mode but i cant.
My question is is there any other way to fix that problem so i can have about 18 pounds of boost and my ecu wount go in to limp mode would like to have it done cheap way thanks contact me at vodolaz19@hotmail.com if you have any info that will help me thanks
Sergy
Old May 31, 2011 | 08:06 AM
  #192
Mike-2ptzero's Avatar
If your ndbw car is going into limp it is doing it because there is another issue.
Did you check for engine codes?
Old Jun 10, 2011 | 02:27 PM
  #193
Jake2.0T's Avatar
will this work on the 2.0 B7's as well or have you heard of anything similar without buying a chip and VAG COM?
Old Sep 7, 2011 | 07:53 PM
  #194
Ryanwillbuyit's Avatar
What is the FPR?
Old Sep 9, 2011 | 12:50 AM
  #195
sergey123's Avatar
i did check for check engine codes and i dont have any and no light is there any other way i can do something to have it run good thanks
Old Sep 19, 2011 | 12:57 AM
  #196
AudiGuest's Avatar
Not a fan of buying no-name stuff from overseas on ebay but has anyone who've done this mod looked into something like this? For their EBC & gauge?
D2power full electronic boost controller EVO CA SPL | eBay
Old Sep 24, 2011 | 04:52 PM
  #197
jamie1210's Avatar
hi iv just joined the forum and have been looking this thred. Wot i know about audis you could wright on the back of a stamp lol..iv seen you talking about the boost settings. and they seem very high. my nissan skyline runs 320bhp and the turbo boost is 0.7 standerd and with boost controler i run it at 1.2bar..are you saying its safe to run a standerd audi turbo at over 1.bar psi.. as i think youll be asking for it to give up on you. but like iv said i know nothing about audis..ps iv posted a few things i need help with but not one reply....am i posting in the right place..im new to the forum and not very good on the old computer.... thanks
Old Sep 24, 2011 | 06:01 PM
  #198
Nearly all of the chips out there for the A4 1.8t run 1.1-1.45 bar, my custom tuned K03 setup ran 1.8 bar(26psi).
Old Nov 20, 2011 | 10:42 AM
  #199
A485's Avatar
If you diode the map and turn up the boost how are you adjusting and monitering A/F ratio?? This mode sounds cool but, unsure how safe it is?
seeing that the computer is getting false signals.
Old Nov 21, 2011 | 01:24 PM
  #200
The ECU does not use the map sensor readings for tuning, it is just there as a safety in case the turbo over boosts.
When you turn up the boost the ECU will see a higher reading at the MAF sensor because of the increased amount of air flow.
