Cheap power, Diode, MBC, and Boost gauge install
hi i got an 1999 audi a4 and i belive there is no MAP sensor and my ecu go in to limp moode where it get ower 10 psi boost and i would do a Diode to control the voltage to send ecu low voltage so it wount go in lipm mode but i cant.
My question is is there any other way to fix that problem so i can have about 18 pounds of boost and my ecu wount go in to limp mode would like to have it done cheap way thanks contact me at vodolaz19@hotmail.com if you have any info that will help me thanks
Sergy
Sergy
i did check for check engine codes and i dont have any and no light is there any other way i can do something to have it run good thanks
Not a fan of buying no-name stuff from overseas on ebay but has anyone who've done this mod looked into something like this? For their EBC & gauge?
D2power full electronic boost controller EVO CA SPL | eBay
hi iv just joined the forum and have been looking this thred. Wot i know about audis you could wright on the back of a stamp lol..iv seen you talking about the boost settings. and they seem very high. my nissan skyline runs 320bhp and the turbo boost is 0.7 standerd and with boost controler i run it at 1.2bar..are you saying its safe to run a standerd audi turbo at over 1.bar psi.. as i think youll be asking for it to give up on you. but like iv said i know nothing about audis..ps iv posted a few things i need help with but not one reply....am i posting in the right place..im new to the forum and not very good on the old computer.... thanks
The ECU does not use the map sensor readings for tuning, it is just there as a safety in case the turbo over boosts.
When you turn up the boost the ECU will see a higher reading at the MAF sensor because of the increased amount of air flow.
