fuel pump stopped working
Hi everybody new to this forum.
im in bother hope sumbody can help me
I own a 2002 audi a4 2.5 tdi v6 quattro
great car till 6 weeks ago.
went to go to work one morning and she wouldnt
start took it to the mechanics,he told me the edc on the fuel pump
not communicating to the pump. does anybody have experience in this
situation. any advice would be great thanks
I am not sure why you are posting a Chevy problem on a Audi forum. However, if you want to use an external pump in your truck it can be done but it need quite a bit of work. The internal pump will act as a restrictor and should either be removed, or the check valve blown open and destroyed with compressed air. Otherwise you can also add a new outlet on the fuel tank. The new pump will need to be designed for fuel injection and provide the proper pressure for your configuration. The return line, if used, will have to be retained. The best solution, and not that hard with a truck, is to drop the fuel tank and replace the internal pump.
jsethwerner225
Nov 14, 2014 01:55 PM
larrye2001
Nov 26, 2005 08:05 PM
