Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
fuel pump stopped working
Old Aug 21, 2012 | 03:45 PM
6702montgomery's Avatar
Default fuel pump stopped working
Hi everybody new to this forum.
im in bother hope sumbody can help me
I own a 2002 audi a4 2.5 tdi v6 quattro
great car till 6 weeks ago.
went to go to work one morning and she wouldnt
start took it to the mechanics,he told me the edc on the fuel pump
not communicating to the pump. does anybody have experience in this
situation. any advice would be great thanks
Old Aug 21, 2012 | 04:52 PM
TheFrostyArab's Avatar
W/ a Diesel get use to going to the mechanic and or lots of preventative maintenance ! Replace fuel pump, common occurrence for diesels.
Old Aug 22, 2012 | 05:04 AM
had the car now for 2 years now.
first time ive had to spend any money on it
part from the usual.
I can get a second hand pump with matching codes
would it still need coded.
our is it plug and play
Old Oct 5, 2012 | 03:29 PM
z28pete's Avatar
Originally Posted by franklin53
My fuel pump stopped working in my 98 Chevy 3/4 ton 2 w/d pickup?
Can I use an external pump to pull fuel out of the tank through the old non working in tank pump? Thanks
I am not sure why you are posting a Chevy problem on a Audi forum. However, if you want to use an external pump in your truck it can be done but it need quite a bit of work. The internal pump will act as a restrictor and should either be removed, or the check valve blown open and destroyed with compressed air. Otherwise you can also add a new outlet on the fuel tank. The new pump will need to be designed for fuel injection and provide the proper pressure for your configuration. The return line, if used, will have to be retained. The best solution, and not that hard with a truck, is to drop the fuel tank and replace the internal pump.
Old Oct 5, 2012 | 11:40 PM
Zachariah's Avatar
You can get a used one, and it should be plug-n-play. Make sure you replace the tank rubber gasket w/ new one and fuel filter too.
Old Oct 8, 2012 | 01:54 AM
Burnell's Avatar
I want to say i have this problem and my trusted mechanic used the plug and play yo want to replace the tank rubber gasket and fuel filter too.
jsethwerner225
Nov 14, 2014 01:55 PM
Stephenwhite990
Jul 3, 2013 08:07 PM
joeynach
Mar 21, 2013 03:56 PM
jchaffee1
Apr 2, 2010 04:34 AM
larrye2001
Nov 26, 2005 08:05 PM
