Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
Fuel System Failure Fuse #37 blown
Old Apr 30, 2016 | 07:07 PM
Bosie's Avatar
Default Fuel System Failure Fuse #37 blown
Hello Audi Forum, I'm new to this forum thing and hoping you can help me. My 02 TT Quattro won't move fuel. I replaced relay and fuse #28 (fuel pump) is fine. So I set out to replace the fuel pump. Once I got to the pump I test lighted it to make sure I had voltage to the pump, none detected. After a bit more research I discovered the fuse #37 (engine timing: petrol) was blown. Each time I replace it, it blows when ignition key is turned on (unless I remove relay before turning on ignition).
Some more back ground. I have owned the car for 9 months. I put all new coil packs and plugs in 6 months ago. Runs so much better. Recently a new battery. Has been a great daily driver until it stalled at a stop light last week and has not recovered.
Im completely stuck at this point. Any help you can be is greatly appreciated.
Thanks, Bosie
Old May 6, 2016 | 11:07 PM
Bosie's Avatar
Default Fuse #37 still blown
Anyone out there that can help? I'm still stuck here. Thanks
Old Feb 11, 2017 | 06:59 PM
bryan100030's Avatar
Hope someone helps with this problem. My Audi A6 2006 3.2L Quattro just had the Fuel filter and oil filter changed. Now she wont start when engine is warm/hot, and will DIE, like at a stop light. Any help would be AWESOME!!! Thank you so much!
rcollins2867
B8 Models
Apr 26, 2016 08:32 AM
Munzter
Jul 17, 2013 05:53 PM
Bartlett
Aug 8, 2006 04:50 PM
Tannis A6 1999
Jan 15, 2006 12:05 AM
ghuston
Dec 20, 2004 03:53 PM
