Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
Hack For Obd2 Sensor
Old 06-02-2009, 12:33 AM
audilady29's Avatar
Unhappy Hack For Obd2 Sensor
my 2002 audi a4 fail massachusetts emmisions for two bad catalytic converters. i tried twice to reset the light, but it came back on after about fifty miles which isnt long enough to retest it. does anyone know if there is a way to hack the obd2 sensor to my emmisions. i cant afford to fix it right now and i really need the car. PLEASE HELP.....
Old 06-03-2009, 07:32 PM
zippy_gg's Avatar
Question
Isn't this what the cat eliminators are supposed to do, by fooling the O2 sensors?
Can anyone confirm or infirm?
Old 06-04-2009, 10:21 AM
Mike-2ptzero's Avatar
What cat eliminators are you talking about? You might just have a bad post cat 02 sensor which is causing the light to come on.
Old 06-04-2009, 10:47 AM
zippy_gg's Avatar
Old 06-04-2009, 11:53 AM
That is used to move the 02 sensor out of the flow when using a Test pipe. Basically it tends to help lower the readings on that 2nd 02 sensor since there is no longer a cat. You can try it but it might only work if your post cat 02 readings are too high causing the CEL to come on, if the readings are too high or your 02 isn't working at all then its not going to do crap.
norcal89451
03-24-2013 03:03 PM
rb7773
06-02-2011 04:21 PM
boosted98a4
05-25-2011 02:37 PM
kltxA3
04-11-2006 01:29 AM
Quick Reply: Hack For Obd2 Sensor
