suddenly won't start
I was doing some rather minor work on my B5 and now it won't start........it feels like the ignition is severly retarded. It will start and run for a second but almost like it was in 1st gear on a bike going 15 mph. I think it has to be something that is causing it to think it is super cold and needs to have full fuel and retard ignition; it has to be a computer set timing issue since when on the starter long enough it fires to what seems to be all cylinders buy my guess is only after a ton of fuel is pumped into the cylinders - it runs for a second, until the excess fuel is burned off and the normal deliver cannot keep up - something it telling the computer to go full retard on the timing.
Does anyone have any insights/service manuel or a Vag-Con (in the MKE area)?
I just put on new wires, checked the coils, and even swapped out ECU's with the same result.
Is it the G62 coolant temp sensor, O2 sensors. etc.....
perfurt
Mar 3, 2013 03:03 PM
