Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
Transmission trouble???
Old Feb 3, 2013 | 06:04 PM
fergusfourrings's Avatar
Default Transmission trouble???
Just swapped out the battery on my son's 99 A6. Started back and then had a p1857 code, every time I would clear the code it would shut engine off. Then I went for a drive and now the tranny is in one gear, put the car in gear with a jerk, and will only stay in one gear. Do I need to disconnect the battery overnight to reset the tcu and ecu? I am also getting a miss fire on cly.3 (P103)
On a happy note: saw the thread on the cruise control module fix, resoldered the caps and now I have cruise! thanks Getting a new scanner that reads ABS codes, then going after my ABS light issue.
Old Feb 3, 2013 | 07:30 PM
Car in FSM, will scanner clear code? Any other suggestions?
Sotka90
May 3, 2012 11:32 AM
DEMPS
Jun 23, 2008 01:25 PM
willbert7
Mar 26, 2008 02:07 PM
abcde
Feb 9, 2007 04:50 AM
marlon_famous
Sep 25, 2006 04:00 AM
