Transmission Trouble
Old Jun 20, 2008 | 12:11 PM
DEMPS's Avatar
Default Transmission Trouble
My 02 Audi A4 has been having trouble switching from Park to Reverse. I can usually get it going if I move to neutral and then to Reverse. Does this sound like a expensive transmission problem or maybe a transmission fluid problem to you?
Old Jun 20, 2008 | 12:19 PM
a4cruiser's Avatar
Default RE: Transmission Trouble
I generally pull the e-brake before letting off the brake and putting it into park so the car wont roll putting presure on the transmission. I noticed when I didn't use the e-brake, it would be a little difficult going from park to reverse.
Old Jun 23, 2008 | 12:02 PM
DEMPS's Avatar
Well the Gear Selector (P R N D) is lighting up and flashing now. The book that came with the car indicates that this happens when the car goes into FAIL/SAFE mode. It also says to take it to an Audi Dealership.
Has anyone else had this problem, or have any idea where I should start to try to diagnose the problem?
Old Jun 23, 2008 | 12:19 PM
DEMPS's Avatar
okay, I'm looking at VagCom Code 17090, P0706.
Can anyone translate this?
Old Jun 23, 2008 | 01:25 PM
Hailjericho's Avatar
Member
What kind of transmission is it? CVT? If so, search the forums for "TCM" and you'll findwhat your problem is.
fergusfourrings
Feb 3, 2013 07:30 PM
Sotka90
May 3, 2012 11:32 AM
willbert7
Mar 26, 2008 02:07 PM
abcde
Feb 9, 2007 04:50 AM
marlon_famous
Sep 25, 2006 04:00 AM
