DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your ride as told by your fellow members.
How to hook up a MBC
Old Jul 18, 2007 | 05:21 PM
  #41
cincyTT's Avatar
I'm make believe
Default RE: How to hook up a MBC
ORIGINAL: smokeU
I thought it was the intake mani?
it is, and after the TB otherwise you wont get vacuum
Old Jul 18, 2007 | 05:25 PM
  #42
onepoint8tee's Avatar
Yeah "intake" is what I meant hahah..
I did install my boost gauge iirc.
Old Jul 19, 2007 | 09:37 AM
  #43
whodatt1's Avatar
Please disregard my question, it does not make much sense as it seems most people use a MBC rather than a digital one with display. Thus as long as you have your gauge hooked up to the IM all is well, as you can just turn the **** until the desired ammount of pressure is reached. (No discrepancies in readings).
[align=left] [/align]
Old Jul 19, 2007 | 10:45 AM
  #44
SacTown_Vlad's Avatar
i got few ?s, i installed mbc last week played with boost level for a little with no problems until I went up to just about 18-20…. i did order Bosch 4 Bar fpr should be here in a day or 2, 1st did I order right one or I need adjustable fpr? and 2nd - do I need anything else for running 20-22psi? oh btw I’m not chipped. and if I do run on 22psi where is this gonna take me… 215-220 just like some of other chipped a4s?
Old Jul 19, 2007 | 11:12 AM
  #45
Why did you order a 4 bar fpr? The stock A4 fpr is 4 bar. No way in hell you can get away with upping the boost much higher than stock levels without a chip or at least without doing the diode mod. Your MAP sensor will put you in limp mode real quick. Youre going about this all wrong. You cant just get a mbc and higher pressure fpr and all of a sudden have 220 hp.... Especially on a 00+ with map sensor..
Also, with the stock turbo, if you gotanything other than a bleeder/gated type mbc, its not going to work out well. What kind of mbc did you get?
You need to do a lot of research before ordering parts and making assumptions.
Old Jul 19, 2007 | 11:19 AM
  #46
opss … i got 4.5 fpr not 4.0… and i did diod mode ….
Old Jul 19, 2007 | 11:21 AM
  #47
Ok.. Maybe I read you wrong... Sorry...
Whats happening when you go above 18psi? Do you get throtle cut w/ EPC light until restart? And what type of MBC did you get?
Old Jul 19, 2007 | 11:23 AM
  #48
it feels like throttle cut, but no cel light or code at all for last 2 days…
Old Jul 19, 2007 | 11:26 AM
  #49
Do you loose all power all of a sudden but the engine doesnt stall? As in- engine idles, but no matter how much you press the gas it doesnt do anythign BUT idle?
What kind of MBC did you get?
Old Jul 19, 2007 | 11:31 AM
  #50
i got some basic simple ball and spring mbc, I had it in for longest time…. I do some loose power… I feels something like you hit red line… [/i]
