2002 Audi A4 3.0 V6 Issues
So I have a 2002 Audi A4 Quattro 3.0 V6, and it has been sitting in my driveway for about a year. Before it sat it had problems with the relays from water getting into the relay box, however it did turn over perfectly fine. Now though I cannot get the car to turn over. All the electrics work inside the car, and I think the ECU still works since the dash came up fine. The dash did say that the clutch needed to be pressed even though I was pressing it down as much as I could. We tried hitting the starter, pumping the clutch, cleaning off some of the relay terminals, and disconnecting the clutch sensor all while being jumped, so the battery is not the issue. We are stumped as to what could be the problem since it seems like it could be a multitude of things, although I suspect it’s something electrical like a relay. We did hear a lot of clicks happening when turning the key so it seems like there’s something happening. The fact that it says to press in the clutch could be telling of the issue. Any advice would be much appreciated!
