Head Unit Stopped Working. Help!
Background:
2000 A6 factory BOSE system
Tapped wires at stock amp to run aftermarket amp and sub but following these directions AudiForums.com - Powered by vBulletin
Also using DICE iPod adaptor
Both have been done several years ago
Problem now:
My radio last week started turning on and off after I turned it on.
Now it will rarely turn on at all.
I noticed last night that even the lights on the Head Unit are not working when it is not, but will cut on if it does decide to play.
I have tried so far to remove the DICE unit entirely and the same problem exists.
I rewired the taps I had in the trunk since they caused my issues once before (i thought this was probably the problem since i had twist connectors on it that have come loose before...before they just caused my aftermarket sub to stop working not the entire stereo tho).
I have tried several times to secure all the plugs in the back of the head unit and play with no luck.
It can't be a fuse since it occasionally works. It seems like a bad connection somewhere, but where would that be if its not on the back of the headunit or amp in the trunk? Or would the HU itself be going bad?
EDIT: replaced with a new HU to test it and it is working...guess my HU just went bad.
Problem now:
Background:
Problem now:
Problem now:
