Installing aftermarket stereo, need 12v switch source
Old Jan 30, 2012 | 10:04 PM
redsoxsurfer's Avatar
Default Installing aftermarket stereo, need 12v switch source
Hello all,
I'm installing a new Alpine HU.
Can anyone tell me the easiest place to find my 12v switch source? I'm using a Metra harness and dash kit, and if you know, the factory harness doesn't have a 12 volt ignition/switch wire that matches up with the Metra harness.
Where do I find it? Typically, I'd go right to the steering coloumn at the key switch, but I'd rather find something a little easier. Anyone know of a spot?
Much thanks...
Old Jan 31, 2012 | 11:32 AM
pa4ul's Avatar
fuse box. I forget which one it is. I can check later if need be. just find something that is on constant when the car is on.
Old Feb 1, 2012 | 09:56 PM
ImTheDevil's Avatar
Redsoxsurfer, what car do you drive? If it's a B5, then you have power terminals inside the dashboard above your left knee. Drop the panel below the steering column, and right near the left end of the dashboard, look underneath. You'll see four power posts there. Three have red wires going to them, and one (labeled 75x) has a yellow cable. The ones with red wires are constant 12v sources (power is always there regardless of the key) and the one with the yellow cable is switched 12v (power on with the key). Terminate your wire with a ring terminal, take off the nut on the 75x terminal, install the wire, and tighten the nut back down. That'll give you ignition-switched 12v power.
Old May 18, 2012 | 09:58 PM
tb30570's Avatar
the 75x also applies to a C5 A6. I tapped into the back-up light curcuit on my though.
Old Jul 25, 2012 | 10:08 AM
bangkok paul's Avatar
i take it that yours is left hand drive? i have a right hand drive will have to go and start taking the dash apart. thanks
Matt 97A4
Jan 20, 2012 04:28 PM
projlightning
Oct 27, 2009 08:43 AM
Jeffreys
Feb 14, 2009 04:44 PM
Blade69
Nov 30, 2007 10:49 PM
north5995
Mar 3, 2006 03:20 PM
